Physical and Chemical Properties of Matter
  • 05:06
Upon completion of this module, you should be able to understand the properties of matter and distinguish between physical and chemical changes. All properties of matter are either physical or chemical. A physical property is a quality or condition of a substance that can be observed or measured without changing the substance’s identity. For example, the freezing point of a substance is a physical property.
The topic "Physical and Chemical Properties of Matter" is available as part of this package. Subscribe this package to get access to this topic.
