Upon completion of this module, you should be able to describe what happens at the molecular level when a solution forms and understand the energies that govern the solution process. A solute is a minor component in a solution that we dissolve in the solvent. The solvent is the major component in a solution that we use to dissolve the solute. Solubility is a measure of how much solute will dissolve in a specific solvent at a particular temperature. Solvation is a process in which solvent molecules surround solutes or ions of solute. Solvation is hydration when the solvent is water.
The topic "A Molecular View of the Solution process" is available as part of this package. Subscribe this package to get access to this topic.
